problem with cisco AP 1260
Hello, I bought for mistake 4  AIR-LAP1262N-E-K9.
this is not an autonomous access point insted I needed a AIR-AP1262N-E-K9
mi question is can the  AIR-LAP1262N-E-K9 work in autonomous mode ? is it possible to install te IOS version of
AIR-AP1262N-E-K9 on it ?
thank you
7 Replies 7
Leo Laohoo
You can convert the AP to autonomous.  Use the following process:  Using a TFTP Server to Return to a Previous Release
my main problem is that the AP does not have an IP Address and I am not able to give it an IP address
because the IOS running on it does not have any conf terminal options... also I don't own any kind of cisco WLAN controller so I Am clueless on how can I give it an ip address...
thank you for your reply
cheers
Riccardo
When you do the mode button recovery it will assign itself an address. It's all documented in the link Leo posted
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thank you i will try it
the link posted anyway requires a MIT ISA server 2006 username and password... and I do not have them of course.
cheers
Riccardo
Here are some other links you can use. You can also search on the Internet LWAPP to Autonomous
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
-Scott
What are document are you reading????
The link I've posted will TAKE YOU DIRECTLY to the proceedure to convert your AP to autonomous with the least amount of intervention and configuration.  If you scroll up and down, you'll get out of topic.
I have posted that link many times already and I've yet to see someone get "lost".
