configure vlan on wireless
jawwalit
Level 3
Level 3
Hi:
i have two vlans in my network vlan 1 and vlan 30 , i try to configure my AP (1200) to have the two vlan 1 and 30,by give to ssid for each vlan, but my problem that the vlan 1 is work AP , but the vlan 30 doesnt being added to vlan, it can authenticate using leap but cant connect to any station in vlan 30, the following are my configuration for the AP:
aaa session-id common
dot11 network-map
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip wep128
encryption vlan 1 mode ciphers tkip wep128
encryption vlan 30 mode ciphers tkip wep128
ssid root
vlan 1
authentication network-eap eap_methods mac-address mac_methods
ssid root1
vlan 30
world-mode
speed basic-1.0 2.0 5.5 11.0
rts threshold 2312
channel 2422
station-role root
l2-filter bridge-group-acl
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
bridge-group 30 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.30
no ip route-cache
bridge-group 30
interface BVI1
ip address 10.100.3.26 255.255.252.0
no ip route-cache
ip default-gateway 10.100.1.1
ip http server
ip http authentication aaa
ip radius source-interface BVI1
logging history errors
logging facility local3
snmp-server community xxx
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps entity
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps wlan-wep
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server enable traps aaa_server
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server host 172.20.228.71 msg
radius-server local
nas 10.100.2.70 key xxx
nas 172.20.228.70 key xxx
radius-server host 172.20.228.70 auth-port 1645 acct-port 1646 key xxxx
radius-server host 10.100.2.70 auth-
5 Replies 5
csilvagni
Community Member
Hi ,
have you configured the switch port to which the AP is connected to in Trunk?
ya, i configure the switch as mode trunk, but doesnt work.
6308ridgeway
Community Member
VLAN 1 is a native VLAN by default. Change ssid root to any VLAN but not VLAN 1.
sean.tobin
Community Member
Below is an example of what we have for our switch orts. We have 5 separate vlans tied to 5 separate security settings. Which range from open to EAP-FAST The IP address of the BVI1 should match your native vlan subnet. Also, how are you doing authentication for the users to be assigned to a particular vlan. We use ACS and tie the ap into authenticating to acs, which will drop them in the correct vlan.
switchport trunk native vlan 170
switchport trunk allowed vlan 76,158,162,165,170
switchport mode trunk
speed 100
duplex full
rmasters
Community Member
I don't see the interface BVI30 in your config. The BVI interface is what ties all the parts together that are in bridge-group 30. Without it, all the pieces in bridge-group 30 are not connected. Add the BVI30 interface and you should be all set.
Rick
