Configuring AP as point-to-multipoint Bridge
greatrush
Hi.
I'm trying to configure AP as point-to-multipoint Bridge.
I've found a sample scenario document from cisco web site as belows:(http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml)
It's for point-to-point Bridge configruation though.
Does anybody have sample scenario for point-to-multipoint Bridge?
Do I have to apply MBSSID configuration to point-to-point Bridge sample which I mentioned?
I'm getting realized why we need WLC...
If I'm success, I'll post it.
Wish my luck.
Thank you in advance.
SWS
fbarboza
Level 4
Level 4
Hi ,
When working with either a point to point or point to multipoint setup we need to configure one unit as the root unit and the other unit(s) as the non root, we need to set the same SSID on all the units, the SSID can be broadcasted or not(it is not required), we need to set the units with the same security encryption method, set on the root the channel to use and distance.
Then you will need to make sure that the units have been aligned one to the other, there is no objects of obstruction and a clear line of sight.
Here is a configuration example of a unit set as root using the 2.4ghz radio, broadcasting the SSID and using WPA version 2 with AES and PSK.
The PSK is cisco12345 and the non root configuration should be the same only set as station role non root.
version 12.4
no service pad
service password-encryption
hostname AP1142AG.246
enable secret 5 $1$cKgH$g4f9xkwWa.9/iwEE9yz590
no aaa new-model
dot11 syslog
dot11 ssid TEST
   authentication open
   authentication key-management wpa version 2
   guest-mode
   infrastructure-ssid
   wpa-psk ascii 7 060506324F41584B564347
username Cisco password 7 072C285F4D06
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm
 ssid TEST
 antenna gain 0
 speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 channel 2412
 station-role root bridge
 distance 1
 bridge-group 1
 bridge-group 1 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 antenna gain 0
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
 bridge-group 1
interface BVI1
 ip address dhcp client-id GigabitEthernet0
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
greatrush
Oh, I'm goint to use 1142N AP anyway.
fbarboza
Level 4
Level 4
Hi ,
version 12.4
no service pad
no aaa new-model
dot11 syslog
dot11 ssid TEST
   authentication open
   guest-mode
   infrastructure-ssid
bridge irb
 no ip address
 no ip route-cache
 ssid TEST
 antenna gain 0
 channel 2412
 distance 1
 bridge-group 1
 no ip address
 no ip route-cache
 shutdown
 antenna gain 0
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
 bridge-group 1
interface BVI1
 no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
I basically succeeded to implement bridge network.
Thank you for your help.
Seung Woo Seo.
