Configuring APs
Islam Nadim
Level 3
Level 3
Hello All,
I'm in the process of configuring an AP to work without a controller, but I don't know from where to start or how to configure. Are all APs configurable via CLI? If not, which are ..
Also, I will install another AP later on, and want users to seamlessly move through the site without disconnecting .. Is that possible?
Best Regards,
Islam M. Nadim
Bilal Nawaz
Hello, Wrong Forum - There are more chances of getting a better response in the Wireless section. Please move to Wireless Mobility, right hand side of your post you should be able to move.
P.S. look at FAT / autonomous AP
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b.html
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Scott Fella
There are many docs that can help you configure an autonomous AP. You just need to search on, How to configure access point. Seamless roaming is tricker on autonomous than lightweight. You would have to be able to use the authentication and be able to setup WDS. Here is a link for that.
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43roamg.html
-Scott
