Configuring Cisco Aironet 1100 Access Point. Please help!
ascolddlocsa
Hi all,
I have dozens of Cisco Aironet 1100 access points, each is managing its own wi-fi with DHCP.
I had to disable dhcp on them because they are on a wired subnet where I am using the static IPs and don't want my wired clients to get DHCP addresses, nor someone to be able to plug the wire into own laptop and get on the network.
It's been working fine with one exception - I need to be able to ping my access points from the central site, and I can't.
What IOS command would enable ICMP echo on my access points in this case?
Please help!
0 Replies 0
