configuring WPA with a SSID and MAC authentication
miclambros
I have WPA_psk configured on the Dot11Raio on a SSID. I also want to use MAC authentication but I continually recieve an error that I need to remove the WPA authenitcation first if I want to configure the MAC authentication on the Manage SSID tab.
I can configure an Access list with the MAC Addresses and then apply this to to the radio interface.
But my question is:
Is it possible to configure both WPA and MAC authentication on a SSID- I have tried it in both the IOS and in the web interface but I recieve an error on both
a-vazquez
Level 6
Level 6
1. Go to SSID manager > the SSID for WPA+PSK, must only have the following selected
a. Open With MAC authentication
b. Key management = Mandatory + WPA checked
c. Enter the Pre Shared Key.
2. The encryption page should have ONLY Cipher+TKIP and select transmit Key 2.
3. Please uncheck Key Rotation, as you are not authenticating to a server that will be providing this service.
http://www.cisco.com/en/US/products/ps5861/products_configuration_guide_chapter09186a0080415887.html
