Connect to wlan - wlan limited - after 3 minutes I get an ip address?
Paul113331
Hello community,
Sadly the vWlc does not stop to hurt me!
Firmware: 8.0.110.0
APs in FlexConnect mode.
I have configured one wlan. No wlan password. I gave this wlan the interface with the name "officeVlan10".
The settings for the interface are as follow:
Vlan Identifier 10
Primary IP address: 172.19.19.3
Netmask: 255.255.255.0
Gateway: 172.19.19.1
Primary DHCP Server 172.19.19.55
nothing else.
Only to mention: When i connect a pc on my switch where Vlan10 is configured I get immediately an Ip-Address of my dhcp server.
When I connect to the wlan, it takes very long to connect. After that my wlan connectivity is limited. Then I have to wait about 3 minutes, after that I get an IP-Address of my DHCP Server and the wlan is working as it should. I have a perfect wlan signal.
Can anybody help me, why I get so late an Ip-Address of my dhcp server?
Thank you again
Saurav Lodh
Level 7
Level 7
refer
https://supportforums.cisco.com/discussion/12344721/vwlc-and-dhcp-problem
Saurav Lodh
Level 7
Level 7
refer
Thank you
Only DHCP Proxy was the solution. That was easy. And I was playing around with DHCP option 82 and ip helper x)
