Connecting cisco anyconnect VPN internally problem
keithli
Dear All,
              I have a question would like to ask regarding on the cisco anyconnect of VPN connection, in our cisco WLC we have 2 SSID. one call "Internal wifi" and i created a new SSID call "guest", and they are in seperate vlan with the same internet circuit, and ACL restricted these subnet to reaching each other, and everything work well and today i found an issue, and also we have a vpn appliance in our office, and i have tried to connect cisco anyconnect vpn under ssid "guest" and i received the following error "the service provider in your current location is restricting access to the internet", as i know there would be an issue to connect something which is internally but the hostname is public IP, in this case can i enable "Allow Local LAN access" check box if split-tunneling is enabled & define "ACE" with 0.0.0.0/32 ? any help would be appreicated
Keith
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/Cisco-Secure-Client-5/admin/guide/b-cisco-secure-client-admin-guide-5-0/configure_vpn.html#topic_B5459554778A483BBDB929E1F250E8CE
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
So I need to use VPN Profile Editor to allow captive portal remediation ?
  - It looks like it , to be honest  : I have no experience with it myself ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
