Showing results forĀ
Search instead forĀ
Did you mean:Ā
Connection LAN to hotspot provider
pbogaerts
Is their a solution were you can connect a LAN wireless to a hotspot of a provider. De PC's are connected to a LAN (wired or wireless) passing a firewall .The users needs to authenticate via de login webpage of the provider.Is this possible with an AP in workgroup bridge mode or is their another solution.
Peter
0 Replies 0
