Connection problem with BR350
vatnet
Community Member
Hi again,
seems my problem is not in combination with the Terminalserver from Microsoft.
The connection interrupts if there is a lot of traffic sending between the both stations.
Message in the log is: Deauthenticate [NAME] MAC ADDRESS : reason "Not Authenticated"
Today, I locked permanantly at the connection. There was no data send between the both stations and the connection was stable.
But the days before I had a lot of transfer volumne over the "line" and it losts connection every couple of minutes.
Is this normal? I hope not? Any solutions? Maybe someone from Cisco knows what to do.
Oh, by the bay. It runs with firmware 12.02T1.
Thanks again
David
derwin
Level 10
Level 10
Hi David,
What sort of average signal strength and quality do you see on the antenna alignment test ?
Do you see a lot of CRC errors on the radio interfaces ?
Do you see a lot of discards ?
At what sort of rate of traffic are you seeing these problems ?
