06-11-2013 03:14 AM - edited 07-04-2021 12:12 AM
Good day All,
Some devices are failing to connect to my Cisco Aironet 1262 AP. So far I have noted the ipad 2, a windows 8 phone and a bang and olufson speaker. Is there something I need to tweak in my config. Other devices connect fine, that is my laptop, desktop and android phone.
Please assist.
06-11-2013 06:25 AM
Can you post your show run-config
06-11-2013 06:38 AM
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$KS7b$x1GR33SyMCDIWIvzJU0GN.
no aaa new-model
dot11 syslog
dot11 ssid PME1
authentication open
authentication key-management wpa version 2 optional
guest-mode
wpa-psk ascii 7 010314575658125C39
username isaac password 7 13150541065F107933
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip wep40
ssid PME1
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid PME1
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 10.14.0.9 255.255.255.0
no ip route-cache
ip default-gateway 10.14.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
