connection problems
stephen.revel
Community Member
We have just rolled out a new warehouse with AIR-AP1220-IOS-UPGRD running system software 12.3(2)JA2 and we are finding problems with the clients dropping off. in the past we have used 12.2(15)JA with no problems.
Any suggestions?
scottmac
Level 11
Level 11
I've heard of some problems with some implementations of 12.3(2) (do a "dir" or "sh flash" and see if you have a bunch of dump files).
Some / many / most seem to be related to the hardware generation of your radios.
I'd suggest updating to 12.3(4)JA. Since we've updated our units, they've been working wihtout a hitch.
Good Luck
Scott
I have also had problems with people dropping, using 12.3(2).
I don't have any dump files tho.
Any documentation on this?
