Console Cable RJ45 to RJ45 to Avocent Cyclades
So I have 2 drops to each AP (2702's on the way). One will be data and the other console access. For lack of better terms, what termination order needs to be used for the console connection to a console server with RJ45 ports. Is it straight through, crossover or rollover? It seems different equipment has required different cable types, and I want to be sure they are terminated correctly. I suppose I could do trial and error, but rather not.
Saurav Lodh
Level 7
Level 7
For console( RJ45) to terminal server , it is rollover which is DB25-rj45
and to access devices using laptop /. pc directly it is rollover, rj45-db9
Rasika Nayanajith
Hi Matt,
This is the console cable you want for this
Cisco 72-1262-01 RJ-45 Rollover Cables
Rasika
**** Pls rate all useful responses *****
