Constantly changing connection speed on Wlan
wgebe
My clients are complaining about the constantly changing of the connection speed to the Wlan. What is the most efficent way to solf this problem. my Wlan is using 1130 type AP's
wong34539
Level 6
Level 6
If you change the speed and duplex settings from auto to fixed on an 1100 series access point's Ethernet port, the auto-MDIX feature on the port is disabled. When auto-MDIX is disabled, you must determine whether to use a straight-through or a crossover cable to connect the access point Ethernet port to another device. If the Ethernet link goes down after you set the speed and duplex to fixed, try changing the Ethernet cable from crossover to straight-through or from straight-through to crossover.
