Showing results forĀ
Search instead forĀ
Did you mean:Ā
Control Path to mobility member is down
rgoble
Level 4
Level 4
WISM running 4.2.176
4402 Controller used as Guest Anchor running 5.2.178.0
This has worked fine for some time now. Started getting complaints about guest wireless and noticed that the  Data Path is up and the Control Path is down. From a command line on the WISM eping to the anchor gets a reply where mping does not. Note no changes have been made to the WISM or the Anchor prior to this failure. Any Ideas? Has anyone seen this before?
rgoble
Level 4
Level 4
A reboot of the Anchor Controller has resolved the problem for now.
