Controller Based Solution for a Flat Network..possible?
sumesh.nair
Would it be possible to have a controller based WiFi solution in a network that has no VLANs-a flat network?Can I have just one SSID mapped to the default vlan..just want to ensure that creation of VLANs would not be necessitated.
Rgds
Sumesh
Scott Fella
Yes it is possible to have a wireless solution even if it's a flat network. You can map multiple SSID's to that same vlan, but that would be overkill... But wanted to let you know you can if you want.
-Scott
