Controller-less/ embedded controller WAP
dinghankar
Community Member
Hello people, I have never worked with cisco wireless stuff but recently I have been tasked to provide connectivity to a room, they were initially requesting 8 ports .
Now they require wireless connectivity, this whole setup is layer 2, I basically want to extend the connectivity of a layer 2 switch into wireless connectivity, this is all for an offline environment.
Can you suggest me APs and also if this is possible?
 It is perfect possible. Get one AP with Mobiilty express because it is easier to setup as it has web interface. Plug it on the switch and setup switch port as trunk. The switch probably have an interface vlan for management. You can use the same vlan to manage the Access Point. Put it on the trunk as native in case you are not using vlan 1.
  If you want to keep the wired and wireless client on the same vlan just put it on the trunk also and use the same DHCP for both.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/user_guide/b_ME_User_Guide_810/getg_started.html
Ap model depend on your budget so I will not recommend.
Rich R
I'd rather go for a newer WiFi 6 Catalyst 91xx series AP running EWC on AP ( better than ME on the older AC wave 2 APs) and setup for your basic requirement should be quite straightforward. Something like C9105AXI for a starting point:
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/datasheet-c78-744062.html
(Note the C9105AXW wall-mount variant does not support EWC)
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
