Controller SNMP management
gururajan
Level 2
Level 2
We faced one recent issue with WLC configuration behavior and explaining our observation and workaround we did. If there is an alternate better approach, please suggest.
Requirement
  • Requirement is to manage the WLC (5508 with 7.4 code) using two SNMP managers in different locations. Also these two Servers should use the same community string to manage WLC.
Observation
  • We were able to configure the SNMP community string for one server IP (to allow access) through GUI
  • While trying to add another Server – IP with same community string – it didn’t allow
  • As per the configuration guide, Controller can use only one IP address range to manage SNMP community.
  • So we cannot configure the same community string to allow only two different server IP addresses
Configuration reference>
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/consolidated/b_cg74_CONSOLIDATED_chapter_0111.html
Solution
  • We currently configured the major subnet ( 10.x / 8 - two match both server addresses) and it works fine
  • Also when we tried  0.0.0.0 / 0.0.0.0 , it didn’t work (SNMP was failing)
But this creates a security issue wherein anybody can poll the WLC. Please suggest if something else can be done.
Guru
Scott Fella
This is not paossible.  You would need to have two different community strings in order to not get an error.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott Fella
Scott
-Scott
