09-25-2013 02:11 AM - edited 07-04-2021 12:56 AM
we have a cisco wireless controller: WLC2106 running software version 7.0.235.0
We recently bought two new accesspoints: AIR-CAP1602I-E-K9
My reseller said they should be compatible with each other.
But when i connect them i receive these errors:
*Mar 1 00:13:18.575: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar 1 00:13:18.575: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.3.4
*Mar 1 00:13:18.575: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar 1 00:13:18.575: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 00:13:18.575: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
Not in Bound state.
*Mar 1 00:13:33.571: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 00:13:36.579: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar 1 00:13:36.647: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.16.3.112, mask 255.255.255.0, hostname AP4c00.829a.37ef
*Mar 1 00:13:44.571: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:13:54.571: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar 1 00:13:54.571: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 00:13:54.571: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar 1 00:13:54.571: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar 1 00:13:54.571: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.3.4
*Mar 1 00:13:54.575: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar 1 00:13:54.575: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 00:13:54.575: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar 1 00:13:54.575: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
AP4c00.829a.37ef#
*Mar 1 00:14:04.575: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar 1 00:14:04.575: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 00:14:04.575: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar 1 00:14:04.575: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar 1 00:14:04.575: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.3.4
*Mar 1 00:14:14.571: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar 1 00:14:14.571: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 00:14:14.571: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar 1 00:14:14.571: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar 1 00:14:14.571: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 172.16.3.4
*Mar 1 00:14:14.575: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'ITDS-WLC2106-01'running version 7.0.235.0 is rejected.
*Mar 1 00:14:14.575: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 00:14:14.575: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar 1 00:14:14.575: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
Does my controller have a software version to old for this accesspoint?
09-25-2013 03:25 AM
This is not compatible, 1600 series required min 7.4.x WLC software version
2106 series controller only support upto 7.0.x software code. So you have to have 2504 WLC model (as it is the product to replace 21xx WLC) in order to to support your AP
Rasika
**** Pls rate all useful responses ****
09-25-2013 04:00 AM
HI Mark,
The Your AP requires v 7.4 code on the WLC.
Please have a look at below url under heading "Table 4 Controller Software Releases and the Supported Access Points" and you can see the AP1600 is listed from WLC Software version 7.4 only.
Hope that helps
Najaf
Please rate when applicable or helpful !!!
