Convert 1131 to LWAPP using conversion tool
tverhoeven
Level 3
Level 3
recently I used the conversion tool to convert 5 AP's to LWAP. 3 were in one building/subnet and 2 were in 2 different buildings/subnets. The conversion tool said everything worked but when the ap's rebooted only one out of 5 actually connected to the controller. I had to go touch the other 4 and tell them the ip of the controller.
the one that came up was part of the 3 that lived in the same subnet.
I have DHCP setup across all scopes with option 43 and one of the controllers set as a master.
any thoughts???
thanks
It's probably too late now, but it would have been helpful to see the console logs from the AP's that failed to join the controller.
it happened monday morning and I fixed the last one yesterday morning.
Leo Laohoo
Before you converted your AP's to LWAP, did you endable DNS and/or DHCP (Option 43 and/or Option 60)?
Option 43 in DHCP has been setup across all scopes.
