Convert Catalyst AP to Meraki without WLC
networker9
Hi Experts,
I have a brand new Catalyst AP CW9166I-ROW with catalyst Image.
I need to convert it to Meraki managed and i don't have a WLC.
Is there any way to convert this without registering to a WLC..?
Thanks in advance..
 @networker9 wrote : >So, does the WLC require any licenses for the AP to get registered with WLC.?
                                  Essentially not or not immediately if you would use  a 9800-CL , it will not force any license entitlements for a month, so it's good for that procedure ,
 M
marce1000
   - No  , you need a WLC : https://www.jiribrejcha.net/2024/02/convert-cisco-catalyst-wireless-access-point-to-meraki-cloud-managed-mode/
                                          https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/migrating-dna-to-meraki-mgmt-mode.html
                              (note that you can download and deploy the virtual 9800-CL for free)
 M.
Hi Marce,
Thanks for the advice.
 M
balaji.bandi
You do not have any other option than create virtual WLC and make convertion.
that is the reason cisco always suggest when you ordering order correct one.
BB
