Convert LightWeight mode to Autonomous mode for Accesspoint
iyoshifu
hello,
CCO documents said only convert back from Lightweight mode to autonomous mode.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
Q.if customer purchaced lightweight mode (P/N:LAP-XXXX) first How do they get IOS (means for autonomous mode)? CCO or should they purchase new IOS as spare?
andrew.prince
Level 10
Level 10
Ichihara,
Not sure what the Cisco licensing aspect is on buying a spare IOS AP, copying the IOS off it and using it to install on another! Especially - when the code has crypto-graphic export limitations ?
But you can get the IOS from CCO - with the correct account/support privilages!
HTH.
andrew.prince
Level 10
Level 10
Ichihara,
HTH.
