correction on previous issue:350 WGB's and 1200 AP problem
candiffjp
I have several Cisco 1200 Series AP running IOS JA4. I also have many 350 WGB's running 8.85. When i upgrade the AP to JA15 the WGB's associate with the AP's however the clients connected to the WGB's dont have any network connectivity. All of the settings on the AP running JA15 match the settings on the AP's running JA4.
Any help will be greatly appreciated
sbilgi
Level 5
Level 5
If you are using WEP, try disabling it and check if it helps.
What if LEAP and WEP is required? Apparently after applying 12.2(15) all of our Compaq/HP iPaqs no longer work to get on our network. Note that the other HP pocket PCs work fine. It seems to just be the Compaqs. Also, other devices which use LEAP are also not working.
Ive disabled all encryption. That was the only thing that the Cisco Reps have been able to sugest. Still did not work
Try to disable "Reliable Multicast to WGB" in the radio settings.
