Correlation between floorNumber and floorRefId
wsurala01
Hi guys,
we are working with MSE from some time and few days ago an interesting issue appeared.
Do you know what is the correlation between floorNumber and floorRefId?
As we receive info about the maps from MSE API, it returns the value of the floor 'floorNumber' i.e. it gives us 2.
But after we've subscribed for notifications MSE API returns the users location including 'floorRefId' i.e. 'some long number'.
So the issue is to find the correlation between those two numbers to find out on which floor of the building the user is currently being located.
Any ideas? The best way would be to get it from the MSE with the map infos but I couldn't find how to do this.
Thanks in advance
0 Replies 0
