Could not resolve CISCO-CAPWAP-CONTROLLER
nh6we
Level 2
Level 2
I have a access point in Singapore which is trying to connect to a controller in Canada.  Think I am having a latency issue.  Is there a way of increasing the timeout period to allow the AP to join the controller before the initial request fails?
Rasika Nayanajith
Make sure AP regulatory domain matches the country configured on your WLC. If that all good you can configure this on AP via console & AP should go & register to your WLC.
LAP#debug capwap console cli
This command is meant only for debugging/troubleshooting
Any configuration change may result in different
behavior from centralized configuration.
CAPWAP console CLI allow/disallow debugging is on
LAP#capwap ap primary-base <WLC-Name> <WLC-Mgt-IP>
If not, post the full AP console output while it is trying to register.
Rasika
**** Pls rate all useful responses ****
