Creating wireless network in WH
Yszty
Visitor
I`m planning wireless network coverage for huge warehouse (project in college). Main problem is to provide good network range for scanners between steel shelves, which are only a meter from the ceiling. Warehouse details with planned deployment AP`s in attached jpg file.
My questions:
- Which model and anthena type will fit for that task?
- AP`s are pleaced in good pleaces? (red lines shows anthena
- Any tips?
- Any recommend for book with projecting wireless network with enviroment like WH?
Leo Laohoo
Get a wireless site survey done correctly.
There are so many factors which can make-or-break a good wireless deployment. The cost of correctly those incorrect deployment is about 3.5 times the cost of the original wireless deployment.
Haydn Andrews
I have done many warehouse designs and as Leo says make sure you get a wireless survey done, cable runs in warehouses can cost more than the APs and if you get them wrong it costs even more to move them.
Couple of good webinars to watch to point you in the right direction
https://www.wlanpros.com/resources/survivor-warehouse-wireless-edition-scott-lester-wlpc-phoenix-2019/
https://www.wlanpros.com/resources/warehouse-wi-fi-francois-verges-glenn-cate-wlpc-phoenix-2018/
*****Help out other by using the rating system and marking answered questions as "Answered"*****
