Creating Wireless SSIDs C9800-CL Controller
tppatrick1
Level 2
Level 2
Hi all,
Can you please assist with how to create 2 SSIDs on C9800-CL
I have created 1 SSID Admim-HQ, and it works fine. The problem start when I add a 2nd SSID named Architect-Dept. These two departments are located in the same building and use the same APs. The goal is to have two separate SSIDs for these two departments.
I created my SSIDs Using the advanced workflow, and I only created the mandatory tags WLAN Profile, Policy Profile, and Policy Tag. The other options I left them at default.
WLAN Profile: Admim-HQ
Description: For Admin-HQ
Policy Pofile: Admin-HQ
Policy tag: Admim-HQ
Lastly, I will add the APs into
Tags APs
Policy: Admim-HQ
Site: default-site-tag
RF: default-rf-tag
Second SSID
WLAN Profile: Architect-Dept
Description: For Architect-Dept
Policy Pofile: Architect-Dept
Policy tag: Architect-Dept
Tags APs
Policy: Architect-Dept
RF: default-rf-tag
Once this is done it's either both SSIDs disappear or I only see the one created last. With one SSID everything works perfectly fine, so I am not sure where I am going wrong and how should I fix it.
Thanks in advanced for any assistance to resolve this issue - it's been 3 days now trying to figure out this.
Patrick
9 Replies 9
pieterh
-> that's where you go wrong, you can only assing a single policy tag to an access point
you must add both WLAN profiles to the same policy tag
Policy tag: Main_Building -> assign this tag to the access point
Hi @pieterh,
Thank you so much for your quick response. So, do I have to do it like the below?
Thank you very much
Patrick
yes you can
some remark: don't make it more complex than necessary
if you do create two policy-profiles then you are set for different profile configuration per department in the future
but if the only difference is the SSID name, (same method of authentication etc.) then a single policy profile may be sufficient
after all if both policy-profiles need to be the same you need to guard that every change is made to both profiles
WLAN Profile: Admin-HQ          Policy Pofile: MyCompanies-profile
WLAN Profile: Architect-Dept   Policy Pofile: MyCompanies-profile
Hi @pieterh,
Once again thank you. I will provide feedback tomorrow.
Patrick
Hi @pieterh
I'm sorry I didn't come back with feedback on time. I ended up not completing that task. I encountered some issues, outside of this work but am now prepared to complete it. Please review the attached document and provide feedback on where I may be going wrong, as I could not get it working today. Feel free to make any necessary edits to the document.
Thank you in advance!
As said before, you can assign only ONE policy tag to your access point
if all access points need to transmit both WLAN's, you only need to create a single policy tag
Adding Policy Tag
Name [Admin_HQ]                     Name [Admin_HQ]
Description [For Architect_Dept] Description [For Architect_Dept]
Tag APs
Policy [Admin_HQ]                     Policy [Architect_Dept]
Site [default-tag]                        Site [default-tag]
RF [default]                                RF[default]
Hi @pieterh
Thank you very much for your help. I will be implementing your suggestions on Monday next week and will confirm once it's done. Your support is greatly appreciated.
Mark Elsen
  - Note that during configuring attempts on the C9800-CL controller , you can always have the intended configuration reviewed and analyzed with the CLI command : show tech wireless , feed the output into https://cway.cisco.com/wireless-config-analyzer/ , look for advisories and of course correct all errors if indicated  (red flagged)  , the usage of the tool is strongly advised ,
 M;
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi @Mark Elsen
Thank you much appreciated
