CSCvc36452 - Passwd on AireOS are hashed with PS_STATIC_AES128CBC_SHA1
itkcisco1
The passwords are not hashed; they are just encrypted. The MAC field is just a HMAC protecting the _encrypted_ data; what you want is the iv and passwd fields. The static AES-128-CBC key (presumably what “PS_STATIC” is referring to, I haven't seen a “PS_USER” or “PS_DEVICE” password in the wild) is 834156f9940f09c0a8d00f019f850005, the same used to protect the passwords in “show run” (you can find it a couple of places online, including scripts to decrypt).
So beware, if someone manages to get of the CF card in the controller, you will want to change the password immediately.
Rich R
If someone has physical access to your WLCs I think you have much bigger problems than just the passwords.
Note that that is a problem in AireOS, which is now end of life.
If you still have WLCs running AireOS you should be planning to migrate to 9800 or cloud based current technology.
Rich R
