CSSC with machine authentication in Ms AD
severi
Level 3
Level 3
I need to set the CSSC able to run a machine authetication. My need is to be able to run scripts logon to AD.
In NEtwork Connection Type i select the machine and user connection option, machine and user auth Method EAP-PEAP and machine identity default, machine credential "use machine credential".
Event on IAS is:
Event Type: Warning
Event Source: IAS
Event Category: None
Event ID: 2
Date: 3/19/2008
Time: 11:49:37 AM
User: N / A
Computers: xxxx
Description:
User host / anonymous was denied access.
Fully-Qualified-User-Name = MYDOMAIN \ host / anonymous
NAS-IP-Address = x.x.x.x
NAS-Identifier = WLC_AP
Called-Station-Identifier =
Calling-Station-Identifier =
Client-Friendly-Name = wlc_ap
Client-IP-Address = x.x.x.x
NAS-Port-Type = 19
NAS-Port = 1
Policy-Name = <undetermined>
Authentication-Type = EAP
EAP-Type = <undetermined>
Reason-Code = 8
Reason = The specified user does not exist.
The CSSC put MYDOMAIN (correct) and \host / anonymous (not correct) WHY?
How can I configure the CSSC part of the machine and user credentials credentials ?
Thanks.
Mirko Severi
0 Replies 0
