Customized Web-Auth Bundle
greg.murray
Level 2
Level 2
I am trying to upload a customized web-auth bundle to a WLC 5508 and having some issues.
I have downloaded the web-auth bundle from Cisco and used this as a template to create the web pages.
I seem to recall that there is only a couple of Windows tools that you can use to TAR the file such as TUGZIP and IZARC. Anyway I have tried both and I still cannot get the file to extract. I have tried to strip the file out so that I only send up the login.html page and even this does not work.
I am using a software release 7.0.220.0
The error message I receive when I do a TFTP is
Error extracting webauth files.
Any help would be appreciated
Greg
Scott Fella
I have had to use Power Archiver for early 7.0.x code on the 5508. On the newer code, Power Archiver still works (not free) but 7-Zip works.
-Scott
6 Replies 6
dave-curnow
Community Member
     I used 7Zip to tar my files the only other thing I found was to ensure the tar contains login.html, but it looks like you got that covered..
Dave
Amjad Abdullah
Hi Greg:
I hope you find the answer here:
You can compress the page and image files used for displaying a web authentication login page into a.tar file for download to a controller. These files are known as the
webauth bundle
. The maximum allowed size of the files in their uncompressed state is 1 MB. When the .tar file is downloaded from a local TFTP server, it enters the controller's file system as an untarred file.
Note If you load a webauth bundle with a .tar compression application that is not GNU compliant, the controller cannot extract the files in the bundle and the following error messages appear: "Extracting error" and "TFTP transfer failed." Therefore, we recommend that you use an application that complies with GNU standards, such as PicoZip, to compress the .tar file for the webauth bundle.
Reference: http://tiny.cc/rbqbfw
So double check the size and tarring utility.
Try to use WinRar or 7Zip if the tarring format is the issue.
Amjad
Rating useful replies is more useful than saying "Thank you"
Scott Fella
-Scott
7-Zip worked in the end, but there was an issue with the name and file structure in the tar file.
Once I renamed the folder to login_files and placed the correct files in the right location it worked.
I always use login.tar to keep things simple in all my installs. Glad you got it working.
-Scott
dave-curnow
Community Member
Greg,
     I am glad you got it working.
Dave
