Customizing web passthrough site
boshardy1
Level 2
Level 2
I am looking to do web passthrough on my wireless lan controller but want to add my company's logo to the default website. I cannot find any info on how to customize this, is it just html?
Scott Fella
Here is a link: http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml#webpass
You need to download PicoZip to zip up your login.html and companylogo.jpg file into a tar. Just keep it under 1mb and you should be fine. If you have WCS, you can download the login.tar file and use their code... becarefull not to delete any of the java in the head.
-Scott
