Bookmark
Subscribe
1135
CUWSS home lab requirement
Babak KHorshid
Hello All
I got my CCWNA last week and im planning for CUWSS.
i need to set up a home base lab and with this I think I need some software and hardware because its about site survey. I dont want to buy useless apps and hardarwe so can you tell me what do i need to set up for this course?
I already at work have access to 3702 AP
5508 WLC
and WCS
and thanks for your time
Rasika Nayanajith
I would suggest Ekahau site survey software if you could afford
http://www.ekahau.com/wifidesign/ekahau-site-survey
There are some other vendors also have site survey products
https://airmagnet.flukenetworks.com/estore/software/
https://www.acrylicwifi.com/en/wlan-software/wifi-site-survey-software-acrylic-heat-maps/
Again, this may not merely for your CUWSS exam, but to plan your RF design works.
I would also suggest to see if these CWNP wireless courses get refresh. If so I would go with that.
Rasika
Rasika Nayanajith
Rasika
