CW9166i
tejes1234
Community Member
I recently started to learn about the Meraki wifi and was going to learn it and deploy it.  I went online and purchased a brand new CW9166i assuming that it will work on the Meraki dashboard.  After a lot of technical support calls they told me that it was in the DNA mode and I will need a 9800 series controller to convert it to the Meraki dashboard.  I was hoping that in this day and age a company like cisco would have a cloud based controller than a physical WLC to convert it.  I hope one you fine people can help me go down the right path.  Also on a separate note the AP is getting an IP address but I am not able to use the browser to login to its UI.  Is that normal or do I need a special port number to login.
Anil Vijay
jagan.chowdam
Hi Vijay,
If you have Virtual environment, you can download Cisco 9800-CL controller and install it on your VM infrastructure.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-cl-dg.html
Download link: https://software.cisco.com/download/home/286322605/type/282046477/release/Dublin-17.12.3
Once you setup your C9800-CL controller, follow the document given below to convert them to Meraki persona.
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/migrating-dna-to-meraki-mgmt-mode.pdf
Without C9800-CL or physical appliance, you have to RMA the AP and get the correct Meraki persona AP.
The part number for Meraki persona AP is : CW9166I-MR
And you also need a Meraki MR license for this AP to work with Meraki Cloud like LIC-ENT-1YR/LIC-ENT-3YR/LIC-ENT-5YR
Jagan Chowdam
/**Pls rate useful responses**/
jagan.chowdam
Hi Vijay,
Jagan Chowdam
Jagan
If this works you are a life saver.  I will owe you a strong drink of your choice.  Working on setting this up now.
Haydn Andrews
I believe the WIFI 7 APs are getting rid of this requirement, but currently if the SKU is DNA mode you need to join it to a 9800 first then can convert. If you want to go from the Meraki persona to DNA you need to log a Meraki support ticket.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
bussimulatorid
Community Member
That’s normal — the CW9166i is in Catalyst (DNA) mode, so it needs a 9800 WLC for conversion. You can’t manage it via browser directly. If you want Meraki dashboard support out-of-the-box, you’d need the CW9166-MR model.
