CWA intermittent issue
thms
Community Member
Hi all,
First time posting here.
I’m facing an intermittent issue with CWA on a Cisco Catalyst 9800 (17.12.4) and packetfence, only impacting FlexConnect deployments, central switching works fine.
Issue:
About once a week, can happen more than once though, CWA breaks:
  • Clients connect to the SSID but show “no internet”
  • No redirection to the captive portal
  • No clear errors or relevant logs
Observations:
  • Modifying the redirect ACL even just a description immediately restores service
  • QoS policy changes can trigger the issue
  • An EEM ACL refresh helps as a temporary workaround, but because the failure is silent and generates no usable logs, I have to rely on a daily cron job, which still impact the end users.
Troubleshooting:
  • Client trace shows no anomalies
  • Logs seen in some cases: Redirect ACL failure / Authorization failed  but not during failure window
Questions:
  • Known bugs in 17.12.4 related to CWA / redirect ACL / FlexConnect?
  • Possible ACL/policy desync between WLC and AP?
  • Recommended debugs to catch this during failure?
Thanks in advance
6 Replies 6
Mark Elsen
     - @thms               No direct insights here , but also relating to intermittent issues ; have a try with the
        latest advisory for  17.12  ,= 17.12.6a
    M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
thms
Community Member
@Mark Elsen that's not currently possible as there are still some APs in our infrastructure that don't support version 17.12.6a
          - @thms            Yes they will  , let me clarify , all your access points working on the current
                                   17.12 release will work with 17.12.6a ; cisco did no longer  update the compatibility
                                   matrix after 17.12.3 because the versions after .3 where not sufficiently back tested
                                   on the older access points (also using 17.12.x).    But that has no impact
   M.
       Beauty and terror
      Just keep going
       No feeling is final
thms
Community Member
@Mark Elsen I checked this compatibility matrix and did not find the series of some of the APs that are still in our infra, do you suggest I go ahead and update to version 17.12.6a ?
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#:~:text=Cisco%20IOS%20XE%2017.12.6a
    - @thms                 Yes .      they are omitted in that Table , for the reasons I previously explained
  M.
       Beauty and terror
      Just keep going
       No feeling is final
thms
Community Member
@Mark Elsen I will do some testing in a lab environment and will get back to you if the issue is resolved.
