Data and Control Path down in same subnet
juergen.neumann11
Community Member
hello,
I have a small problem with the construction of a mobility group.
My network consists of two WLC ( 5508 and 2504) Ver 7.6.100
If I create the mobility group , the data and control path doesn't come up. The two controllers has management interface in the same subnet.
So very flat the installation...
Ping work, Mping don't work.
Has anyone an idea ?
Greeting from Germany
Juergen
Stephen Rodriguez
can you post the output of "show mobility summary" from both the controllers?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Rasika Nayanajith
Check whether both WLC configured with same virtual IP address as well
Rasika
*** Pls rate all useful responses ****
The problem has been solve by uncheck " new mobility"
Thanks for the follow up  & post the resolution you got..
