Data rates for APs controlled by 4400 controller
MASP
Community Member
Hi guys,
I am wondering if it is possible to disable a 802.11 data rates (no matter which one) only for some of the APs controlled by a 4400 controler ?
To be thorough, I want to disable the 802.11a/n data rates 48Mbps and 12Mbps only on 3 APs on a 4400 controller in v7.
Can I disabled it ?
Thanks for your feedback,
Marien.
Leo Laohoo
Yes.
Nope.  IT will affect ALL the APs.
MASP
Community Member
Thank you leolaohoo for your feedback.
So the only way to do this is to install some autonomous APs ... (not what I expected)
If anyone else have an idea, do not hesitate to post your thought.
