dBm converted to mW in wireless network
eigrpy
Level 4
Level 4
Based on the formula below, dBm 19.979 should be 99.51mW, but a window box in Ekahau shows it is 25mW. Please see the screenshot below. Are there any one who can tell what the issue is? Thank you
P(mW) = 1mW ⋅ 10^(P(dBm)/ 10)
Nicolas Poirier
Level 4
Level 4
Hello David,
Don't forget to take the antenna gain into account.
With an antenna gain of 4 dB and a transmit power of 25 mW, the EIRP is 25 x 4 = 100 mW (20 dBm).
PS: here is the EIRP formula: (RF Power - cable loss) * Antenna Gain
Rasika Nayanajith
Hi David,
I think that should be a bug of Ekahau, pls report to them and they should fix it
Rasika
*** Pls rate all useful responses ***
Nicolas Poirier
Level 4
Level 4
Hello David,
I think you are right. Thank you
EIRP = Transmit_Power - Cable_Loss + Antenna_Gain
25 mW == 14 dBm
gain of 3802i dedicated 5GHz antenna = 5 dBi
14+5=19
