Deauthentication
deb.bridson
Community Member
There are 6 1200 series APs in this building. Users accessing AP_1 are having problems authenticating. Would someone mind telling me what the following message retrieved from AP_1 logs might indicate?
Interface Dot11Radio0, Deauthenticating Station 0012.f0e0.404a Reason: Previous authentication no longer valid
b.hsu
Level 11
Level 11
This message indicates that the client has disassociated from the AP. When there are several APs in the vicinty, the clients may often disassociate with one AP and reassociate with another AP. This is because the clients are always scanning for better signal strengths and when they find another AP with a better signal strength they jump to that AP. To avoid this the design of the WLAN network must be reconsidered and probably a site survey should help.
ralphbrown
Community Member
Hi Deb...did you every resolve this problem? I am going through it right now. Still looking ofr a solution.
Ralph
