Debug capture in cisco controller
Wifi_Eshwar92
Level 3
Level 3
Hello Team,
Is it possible to do debug that will be saved after the session as well? If the issue occurs very random time and live capture is almost impossible as we donno when it will reoccur. In this scenario how we can capture and store the debugs in cisco controller.
Its like how we collect in aruba controllers "tar logs tech-support user mac <client-mac>” which will contain logs for that specific user brief amount of time.
Thanks in advance.
Rasika Nayanajith
In Cisco WLCs, you have to be in  a active session (console or ssh) in order to capture a client debugs
Rasika
