default mywifi.cisco.com/webui login and password for C9115AXI-S
stevenlsf
Hi, all
  I am new to network IT and CIsco product. The C9115AXI-EWC-S was installed on the ceiling during renovation without configuration. the WAP is connected to Cisco 9300L PoE. After I tried to login to the CiscoAirProvision wifi and it prompts to mywifi.cisco.com/webui(192.168.1.1). I tried a few combination searched from web like admin/admin, admin/password, admin/cisco, cisco/cisco123, admin/(Serial Number), cisco/(Serial Number) and none of them worked. I also didn't find anything from any labels on the ship box and the WAP itself. Assume it is a bit difficult to connect the console cable to the WAP on the celing now, may I know if there is any other default password or other alternative I can login into the WAP to do the configuration. Thanks.
2 Accepted Solutions
@stevenlsf
 Use user name "webui" and password as "cisco"
Mark Elsen
        - Try "webui" and password "cisco"
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
@stevenlsf
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
