Default power level for AP1240
huangedmc
Level 3
Level 3
Does anyone know what the default power level is for 1240AG's in U.S.?
I've looked for it in documents I found on cisco.com but they only tell you what the max power is and how to configure them.
Also, how do you see what the current power level is in CLI?
Rob Huffman
Hi Kevin,
The AP default local power level is maximum.
show running-config Displays the current access point operating configuration
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_command_reference_chapter09186a00804e631f.html#wp2459939
Have a look at he attached doc for a list of maximum and shipped power levels for the AP1240 in variuos countries including the U.S
http://www.cisco.com/en/US/products/ps6521/products_installation_guide_chapter09186a008071c3f7.html
Hope this helps!
Rob
Thanks for the quick response.
I know that show run gives you the current config, but I'm looking for a specific "show" command that would give you the power level.
Besides, I don't see power level in my "show run".
