Default ssid
rburgess007
Community Member
how do i remove a default SSID?
All default SSIDs are always there. Just disable all that you don't need.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Does that remove it's accessibility to other APs?
CMR
Meraki Community All-Star
Yes, just disable any that you don't want and they will be completely inactive and not seen.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
A disabled SSID is disabled on all APs. An enabled SSID can be controlled on which APs you want to use the SSID.
