detect rogue AP sending with 160 MHz Channels
maamann
is there a Way to get a list from Rogue AP´s where sending with 160 MHz Channels ?
I could extract it from the CLI on a C9800 but i am looking for a much elegant solution.
Maybe someone knows how to get this information  from Prime or DNAC.
Contents of the list should be,  AP-Name and AP-Location where sees the rogue AP where sending with 160MHZ would be nice.
Regards Markus
Scott Fella
I don't know if you can use rogue detection on just specific channel widths.  If you can't get this info on the 5ghz, I would think that you would not get that either on the 6ghz.  If you have a way to get that from the CLI, you should be able to script/automate that and parse the data to what you want.  It almost seems like a spectrum analyzer is what you need.
-Scott
