DETECTION ROUGE AP ISSUE
Luigi Gnerre
Visitor
Hello everyone,
on my wlc 9800 (verisone 17.3.6) some AIRCAP-2802-E-K9 detect as rouge AP some AIRCAP-1702-E-K9.
someone have the same issue on the WLC 9800?
Best Regards
Luigi
6 Replies 6
 But those AIRCAP-1702-E-K9 are yours?  Are they connected to the same WLC 9800 ?
yes, the AP AIRCAP-1702-E-K9 and AIRCAP-2802-E-K9  are connected on the same WLC
Luigi
Do you have only one WLC or it is a cluster of two?
a cluster of two AP
Prince.O
Are these APs connected to your wireless controller ?. If so , then you should reach out to TAC to investigate further for root cause analysis
JPavonM
There are tons of well-known defects with regard of Rogue AP and AP 3800/4800 series in C9800.
TAC always sugegest to upgrade to latest. I did it and running 17.9.3 most of them have disappeared, but be sure they will return due to the multiple defects these AP series with Marval chipset have.
