Device profilling with WLC - wrong result with Nokia
severi
I have created a Wireless Device Policy Classification into a WLC with 8.0.110.0
The WLC configured to local profile, profile the nokia device (with windows-mobile) as a Windows-Workstations.
How is possible?
Regards.
Mirko Severi.
7 Replies 7
Saurav Lodh
Level 7
Level 7
Try updating profile list :
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-6/configuration-guide/b_cg76/b_cg76_chapter_0111101.html#task_D1B98B9EAB33428F842C22156BE883D5
Hi Saurav.
I have already done!
Any other ideas?
Did you download the IEEE oui.txt and seach for the MAC address of the device to see if it's in the list? If it's not in the list, you can manually add that and upload that to the WLC.
-Scott
-Scott
Hi, Scott.
Thanks for your help.
In this case, my device is Lumia 635 and its MAC is B8-4F-D5-D6-3F-3C
In the oui there is
B8-4F-D5   (hex) Microsoft Corporation
B84FD5     (base 16) Microsoft Corporation
                     1 Microsoft Way
                  Redmond Washington 98052
                 UNITED STATES.
The WLC profiling the device right!
Is possible to put an exception?
Regards.
Mirko
What do you mean an exception?  You want it to say Lumina than Microsoft?  You can try to modify the oui and see.
-Scott
-Scott
I would to profile all mobile device and in this case also Lumia 635.
Any ideas?
Regards.
Mirko.
That would be very tedious do edit all that.  The oui is very specific on what manufacture owns that mac address string and that is as far as it goes.
-Scott
-Scott
