Devices able to connect to SSID from APs, not assigned IP addresses
cmonte0247
We have configured two Lightweight Access Points using a 3504 WLC on Packet Tracer. Both access points are connected to the WLC, and have been assigned IP addresses through DHCP from the WLC. Both also state they are providing the WLAN we created. Authentication for the WLAN is configured using WPA-2 Personal. The SSID is enabled, and its WLAN has FlexConnect local switching and local auth enabled. Both APs are FlexConnect compatible as well and are in a group in the WLC.
Our laptops are able to detect this SSID when creating a new profile in the "PC Wireless" app on the desktop, and stated they have successfully connected to the AP after entering the PSK, however, they are not actually assigned an IP address via DHCP, and have a 169.254.x.x address.
We wanted to know if there are any other configurations to check for or any issues in our topology that are preventing DHCP from working on these end devices, as it does work on our APs. Attached is our Packet Tracer file. Thank you in advance!
Mark Elsen
      -   FYI : Community group for Packet Tracer project questions
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
