DHCP ALLOCATION INCORRECT ON AIRONET APs
veltech
Hi All,
Have just made some changes to a network to add 2 SSIDs to give basically guest and office access over the Aironets. Equipment in network is:
Cisco ASA 5510
Cisco 3750 Switch
Aironet 1231G K9  x 2
basic config is VLAN 1, VLAN 10 and VLAN 20 on switch and each has its own DHCP pool. The Aironets are configured with the VLANs 10 and 20.
PROBLEM
When connecting to the Aironets with a wireless client, on one SSID the ip address assigned by DHCP is in correct network, but when we try to connect to the other SSID we get an ip address from the wrong DHCP pool. To eliminate a config issue on switch I have connected a PC directly to the switch and test allocation of ip address for each DHCP pool and it works fine. The problem is only with the assignment from the Aironets.
Any ideas on this one ?
Rasika Nayanajith
Are you able to attach your 1231 & 3750 configs (.txt files) to see ?
Rasika
