DHCP configuration issues with Wireless
q-le
Level 5
Level 5
Hi ALL,
We currently have WLC 5508 setup with our Windows DC setup as DHCP server.
Currently when a laptop or client connect to our wireless it got DHCP IP from our domain DC server.
it is setup with /24 and it works well and there is no issues.
However we recently  just run out of IP adds so we increase our range to /22.
hence we update the new settings in Scope in our DHCP server, and in WLC interface set up.
For testing purpose , i just give myself an static IP add in the new range /22 and cannot get it to work.
how does dhcp WORK in  WLC  ?
did i miss a step in the configuration ?
Any advise are much appreciated.
Peter
so how do we test for /23 or /22 where we do not have enough devices to reach it.
If you already changed network to /22 and you got ~250 devices on that new subnet working properly, then do not worry about.
Your network will work without any problem for ~1k devices. Assigning 172.18.155.1/22 does not prove any special thing.(ie capacity point of view)
Rasika
Rasika Nayanajith
Hi Peter,
Under WLAN Advanced configuration, there is a tick box for allow DHCP address, if you tick that option, then static client won't be allowed
I would suggest you to test your client to be DHCP & see if it get IP from /22 network you mapped
Rasika
*** Pls rate all useful responses ***
Hi Rasika,
Thank you for your advice.
we have currently  approx 254 devices and dhcp work well for /24.ie 172.18.152.0/24
we just update to /22 for future growth.
That is why we try to emulate static IP ie 172.18.155.1/22.
Peter
Rasika
Thank you.
Peter
