DHCP for LAN and WLAN
Carsten Radke
<p>My problem is to get an IP with the WLAN-Clients. They could connect but didn't become a dhcp-lease.</p>
<p>I've looked in all the other posts for dhcp, but couldnt locate my problem.</p>
<p>Any help is welcome. Config is attached.</p>
So if the wireless clients get associated to the AP and they do not get a valid IP Address (range of 192.168.10.200 to 192.168.10.210), what IP Address(es) are they getting?
If they are not getting the default 169.x.x.x IP Address then there could be a DHCP server nearby? If the answer is yes (that they are getting a valid IP Address from a nearby DHCP Server), IP Helper Address?
8 Replies 8
Leo Laohoo
So the clients get associated to the wireless AP but can't get ip addresses from 192.168.10.200 to 192.168.10.210?
thats right
The Client doesn't get an IP and the only dhcp server is on the router.
Could it be that i've to diable the ip inspect ?
Carsten
I am having the same issue with a new 1231 AP. It gets a windows (local) IP of 169.x.x.x.
Try adding the bridge-group 1 command to your Dot11Radio0.1 subinterface. I've seen this problem before and it generally relates to bridge-groups.
Thats was the problem, thanks jeff.
I changed the config in:
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 45
ssid Carsten
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
rts threshold 2312
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
and its working fine.
