08-15-2015 05:38 PM - edited 07-05-2021 03:46 AM
Hi Everyone,
Via WLC i have configured static ip for the AP.
Do i need to config dhcp option 43 on server now?
As per my understanding if you configure static IP on the ASA then i do not need dhcp option 43 right?
Will client still get the IP address from the server if dhcp option 43 is not configured?
MAhesh
Solved! Go to Solution.
08-17-2015 10:44 PM
HI Mahesh,
For clients nothing to do with option 43.
Option 43 is for Access-point to find the controllers.
Don't forget to rate helpful posts
08-18-2015 12:35 AM
My only concern is Client PC getting IP from Server do I need option 43 for that on sever?
PCs, by default, do not understand DHCP option 43.
Besides, why would the PCs be in the same VLANs as the APs?
08-15-2015 11:11 PM
Via WLC i have configured static ip for the AP. Do i need to config dhcp option 43 on server now?
Depends. DHCP Option 43 is one of the two mechanisms that will enable APs to find the WLC.
I don't understand why anyone wants to disable DHCP Option 43. If it ain't broke, don't fix it.
08-17-2015 07:31 PM
MAhesh
08-17-2015 10:44 PM
HI Mahesh,
08-18-2015 01:54 PM
Many thanks Sandeep.
MAhesh
08-18-2015 12:35 AM
08-18-2015 01:55 PM
Many thanks again Leo for your help.
MAhesh
